Date/Time: Tue, 04 Mar 2025 19:16:44 +0000
NYSE stocks with volume profile - SC package
View Count: 503
[2021-12-31 16:00:06]
manfretto - Posts: 117
What SC package I need to analyze NYSE equities (company stocks) with volume profile? Do I need Denali for this or not really? Is service package 5 ok? What about real-time as well?
Date Time Of Last Edit: 2021-12-31 16:01:02
[2021-12-31 18:03:59]
John - SC Support - Posts: 38369
In order to use the Volume Profile, you just need to be on the Standard Package.
In terms of the data, we are expecting to have our new data feed for U.S. Stocks running in January, so if you can wait for that, then we recommend waiting for it. It will be part of our Denali Exchange Data Feed.
Otherwise, if you need data right now, then you can get it from us through our Sierra Chart Exchange Data Feed. We would switch you over to the new feed when available. To setup the Sierra Chart Exchange Data Feed follow these instructions:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions
