Date/Time: Tue, 04 Mar 2025 19:09:32 +0000
Price Ladder Auto Scroll
View Count: 558
[2021-12-31 13:21:26]
User357489 - Posts: 72
Hello, is there an option for the DOM to automatically scroll up and down with the price as opposed to flying away and me scrolling to find it. Instead of always having to click re-centre ?
[2021-12-31 15:39:55]
John - SC Support - Posts: 38369
What you are describing is the default behavior for the DOM - which is the Automatic scaling. Refer to the following:
Chart Scale and Scale Adjusting: Automatic (Scale Range)
Be sure to check your scale settings and ensure that it is set to Automatic.
