Date/Time: Tue, 04 Mar 2025 18:23:23 +0000
[Programming Help] - Would like to have a Color bar base on Alert condition for a Cumulative Delta Study. BUT..
View Count: 561
[2021-12-31 04:22:14] |
GravisHTG - Posts: 306 |
I cant find the way to make it work when the number have both more than 0 and less than 0 to be considere. I go with (((High minus Low)*2)/2) of [0] >= (((High minus Low)*2)) of [1] My goal is to paint the bar if the Bar size is greater than 2 times of the last bar. It work on some occation but now I realize , it just wont work if in the negative , How should I approach it to make it work at all time ? Just had an idea - Will use the ATR on the Cumdelta to get the bar range than plot one the graph with Color bar. Date Time Of Last Edit: 2021-12-31 05:21:21
[2021-12-31 13:58:22] |
Sawtooth - Posts: 4179 |
Try this: =ABS(ID1.SG2-ID1.SG3) >= ABS(ID1.SG2[-1]-ID1.SG3[-1]) *2 where ID1 is the Cumulative Delta Bars study. https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#ABS_Function |
