Date/Time: Tue, 04 Mar 2025 19:11:57 +0000
extending rectangle
View Count: 535
[2021-12-31 02:39:54] |
Ken Smith - Posts: 58 |
Is it possible to have the extending triange be global, so that if I draw and extending triange on a TPO chart, that same box will show up on my other charts? thanks ken |
[2021-12-31 15:27:44] |
John - SC Support - Posts: 38369 |
Refer to the following for how to copy a drawing to other charts: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
