Date/Time: Tue, 04 Mar 2025 21:15:24 +0000
Resetting PNL on Trade Window
View Count: 999
[2021-12-30 23:14:06] |
Steve Leon - Posts: 311 |
I wanted to know how to reset my PnL to zero at the start of the Globex (overnight session) on the ES (eastern standard time). I believe it is resetting at midnight right now; although my broker (Edge Clear/Phillips) considers those trades for the following day on their statements (I believe) Thank you Steven Leon |
[2021-12-31 00:01:09] |
This is controlled through this Chart Setting: Chart Settings: Start Time for Trades List (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-12-31 00:02:08
[2021-12-31 00:02:12] |
Prior post has been updated with correct link.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-12-31 00:02:18
[2021-12-31 16:20:40] |
I was able to find the chart setting. I changed it to !8:00:00 (6 pm EST open of Globex). I was trading this am before i did that. After I switched it, it rezeroed my PNL. I assume this is expected ? I also had some questions about the Trade activity Log I am attaching a screen shot. I was able to get Trade Statistics yesterday but then for some reason I have been getting a blank log ? I was trying to set up commissions for the symbol I am trading I set the commissions and nothing seemed to happen i then checked "Global commissions in the symbol section and still nothing happened. I checked use commissions box in the trade activity log and still not getting anything. Now I also am not getting any data in the trade activity box Thank you for all your help this year John. Happy New Year Steve |
[2021-12-31 16:44:20] |
This is due to another issue which has been fixed. Update to prerelease 2341: Software Download: Fast Update We have locked out version 2340. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-31 17:22:33] |
I downloaded pre release 2341 I can now see the trade statistics in the activity log but i dont see anything under commissions ? Thank you |
[2021-12-31 18:29:34] |
John - SC Support - Posts: 38369 |
Make sure you have selected the "Use Commission" option at the top of the Trade Activity Log and then select the "Apply" button.
[2022-01-03 22:58:47] |
thank you that resolved the issue
