Date/Time: Mon, 14 Sep 2026 13:40:37 +0000
[User Discussion] - market depth historical graph
View Count: 992
[2021-12-30 19:25:50]
wildpanther1945 - Posts: 48
Hello SC Support,
I only trade US equities and not sure if I'm setting this up correctly. My question is, what type of symbol do I need to select if I'm trading NYSE and NASDAQ stocks/equities? There's so many symbol that I don't know what to select. I searched the support board but none I can find an answer. Thanks in Advance.
Here's the step:
Make sure your Sierra Chart Service Package is set to a Service Package that includes Advanced features.
Select Global Settings >> Symbol Settings on the menu.
Locate the symbol or symbol pattern for the Symbol in the list of symbols, that you want to use the Market Depth Historical Graph study with. Select that symbol or symbol pattern????
[2021-12-31 03:58:06]
1+1=10 - Posts: 270
Stock symbols need to be manually entered: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#StockSymbols
