Date/Time: Tue, 04 Nov 2025 18:18:02 +0000
volume multiplier
View Count: 870
[2021-12-30 15:40:48]
User407641 - Posts: 4
hi i recently downloaded volume multiplier changer DLL v 2273
it was working for several days since i started it... but today its not showing me options for the multplier change.... and yes its at the bottom of the study and i didnot do any new settings on my sierra.. i tried to turn it off and start again. but no luck...
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=58873
[2021-12-30 22:11:13]
Sierra_Chart Engineering - Posts: 21306
This is a custom study. We are not able to help with this. You need to contact the developer about this.
[2022-04-01 04:25:44]
is it possible to put the volume price multplier in task bar,, instead of going to chart settings and change it?
