Date/Time: Tue, 04 Mar 2025 17:53:01 +0000
Connecting to data in free trial
View Count: 526
[2021-12-30 15:25:28]
User589284 - Posts: 6
Hi. I just created an account.
I've been told to connect to data feed: SC DATA - All services.
But it indicates that it is not included in the package.
What should I do?
[2021-12-30 22:12:15]
Sierra_Chart Engineering - Posts: 18651
Your account has been activated and the usage time extended if necessary.
If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu.
After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit".
