Date/Time: Tue, 04 Mar 2025 19:14:38 +0000
how to limit vertical graph?
View Count: 549
[2021-12-30 13:56:24] |
User278398 - Posts: 291 |
hello all. i want to limit the vertical graph that i always see the numbers between 1 to 2 (no materrs what is the actually result)... how can i do that? thank u. |
[2021-12-31 11:02:57] |
someone ?
[2021-12-31 11:53:24] |
User907968 - Posts: 833 |
Chart Scale and Scale Adjusting: User Defined (Scale Range)
[2022-01-01 17:21:42] |
Yes use a User Defined scale: Chart Scale and Scale Adjusting: User Defined (Scale Range) Instructions to access the Scale Window: Chart Scale and Scale Adjusting: Opening the Scale Settings Window for the Main Price Graph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-01 17:22:21
