Date/Time: Tue, 04 Mar 2025 19:01:40 +0000
Lmax Change%
View Count: 540
[2021-12-30 12:18:28] |
User78442 - Posts: 260 |
My quoteboard Change & Change% as with the embedded DChg% on charts is not a daily change (see enc.) Is this just an issue with Lmax or can I fix it? |
[2021-12-30 14:44:52] |
We will check on this.
[2022-01-03 02:44:41] |
We apologize for this issue. There was a problem. We are correcting it now.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-03 02:45:06
[2022-01-03 03:34:53] |
Looks better Tks
