Date/Time: Tue, 04 Mar 2025 18:21:15 +0000
no data from 29.12.21 (znh22)
View Count: 507
[2021-12-30 07:35:30] |
Пользователь488020 - Posts: 100 |
hello, there is no data on the historical (daily) chart for December 29, 2021
[2021-12-30 15:04:45] |
Follow the instructions here: https://www.sierrachart.com/index.php?page=doc/helpdetails6.html#h6.3 Follow step 4 instead of step 3. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
