Date/Time: Tue, 04 Mar 2025 18:14:56 +0000
Teton order routing 32bit.
View Count: 568
[2021-12-30 05:10:58] |
User832670 - Posts: 8 |
Is the Teton order routing available on the 32bit builds? My version is 2138. I want to open an account at EdgeClear and use Sierra for charts and execution. Thanks. |
[2021-12-30 14:57:40] |
There is no longer support for 32-bit operating systems with Sierra Chart. You really must update. 32-bit is so out of date at this point in time. There is no reason not to update. Hardware platforms have been 64-bit, for more than 10+ years now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-30 15:11:23] |
Is that a yes, or a no? I see under "Data/Trade Service Settings" There is a selection for "SC Futures Order Routing/Data." Thanks. |
[2021-12-30 15:15:02] |
The answer is definitely no.
