Date/Time: Thu, 06 Mar 2025 09:34:46 +0000
[Programming Help] - Spreadsheets do not have standard normal, cumulative normal distributions
View Count: 555
[2021-12-30 04:27:16] |
dk90 - Posts: 33 |
Hello. I need to use the normal/gaussian distribution and the cumulative normal distributions in my spreadsheet. Seems strange that your software would not support such basic statistical distributions. Am I missing something? Thanks.
[2022-01-13 18:28:54] |
dk90 - Posts: 33 |
Can I please get a response to this question? Thanks.
[2022-01-31 05:59:36] |
The available functions are documented here: Spreadsheet Functions If they are not available, then we just do not have them. There is also ACSIL available to you: Advanced Custom Study Interface and Language (ACSIL) If there are particular Excel type functions you are looking for give us the exact names of them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-31 06:00:27
[2022-01-31 06:06:51] |
dk90 - Posts: 33 |
I am looking for the following Excel type function: NORM.S.DIST
[2022-01-31 06:47:28] |
We will see about implementing that. We will review it.
