Date/Time: Tue, 04 Mar 2025 17:58:51 +0000
Unable to download latest version of sierra
View Count: 446
[2021-12-29 16:55:09] |
User985092 - Posts: 13 |
i need to download the latest version of sierra to fix rithmic connection and graph history issues. I am using sierra on IMac through Parallels desktop. The error message appears on my desktop screen and not in sierra: so, I don't know how to send it to you as an attachment ...
[2021-12-29 16:57:10] |
John - SC Support - Posts: 38368 |
There typically is not much we can do with regards to the installation on a MAC. Therefore, we can only recommend using the Zip Installer. Refer to the information here: Software Download: Sierra Chart Zip Installer For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
