Date/Time: Tue, 04 Mar 2025 18:01:24 +0000
Using AMP as Broker, but using Sierra Chart fir order routing and data feed
View Count: 570
[2021-12-29 14:40:10]
User989346 - Posts: 7
I realize that TT is not available to new users, but what do I need to do to connect my broker, AMP, with Sierra Chart's data feed and order routing. I rather have Sierra Chart do both the data feed and order routing. However, I get no information on connecting my broker to Sierra Chart. I keep getting information on CQQ, Denali, and TT, Teton Order Routing Services, but I'm getting no information on just simply connecting my broker to Sierra's full services. Please don't send a link to a page with no explanation. I'm getting nowhere without an answer to a specific question.
[2021-12-29 15:39:06]
John - SC Support - Posts: 38368
You cannot do what you are wanting. AMP does not support the Sierra Chart Order Routing Services.
Therefore, you have 2 choices:
1) Switch brokers to one that supports the Teton Order Routing Service, where you will then get both the order routing and data from us. You will find a list of the supported brokers at Step #2 at the following link:
Sierra Chart Teton Futures Order Routing: Setup Instructions
Then follow the rest of the Setup Instructions in that section.
2) Stay with AMP and get setup with order routing through CQG or Rithmic, but use the Denali Exchange Data Feed for your data. In this case, you would follow the appropriate setup instructions for whichever order routing service you get setup with:
For CQG:
CQG Trading Platform Service: Setup Instructions
For Rithmic:
Rithmic Trading Platform Service: Setup Instructions
Then to setup the Denali Exchange Data Feed for the CME Group data, you would follow these instructions:
