Date/Time: Tue, 04 Mar 2025 18:19:05 +0000
[User Discussion] - User Contributed Studies / find files
View Count: 810
[2021-12-29 05:42:32]
User793846 - Posts: 4
Dear Support,
I was a regular user a couple of years back. Regularly I used two studies from User Contributed Studies, they were "Gann Swing" and "Gann HiLo Activator"
I was able to make small adjustment and re-compile the studies and they worked.
After searching through everything I was not able to find the code to make these changes.
Can anyone tell where those indicators are found to access the code?
Your help is greatly appreciated.
[2021-12-29 13:15:01]
JohnR - User831573 - Posts: 317
Here is the link to User Contributed Studies, but doing a search on "Gann" did not find anything.
User Contributed Advanced Custom Study System Source Code
But there are built-in studies for them. I did not see if there was source.
https://search.sierrachart.com/?q=Gann&submitted=true
Hope that helps.
JohnR
[2021-12-30 18:27:50]
User90125 - Posts: 715
Look thru this thread for more info (including source code):
New Gann Swing Chartist Plan oscillators
IMHO, the Gann HiLo Activator is the best of the lot.
