Date/Time: Tue, 04 Mar 2025 17:51:44 +0000
Accessing Denali data
View Count: 446
[2021-12-28 15:11:42] |
User516363 - Posts: 3 |
Thanks! I need data only for CME S&P500 e-minis (current contract ticker ESH22). Yes I read that page fully yesterday, and Im waiting for my broker AMP to give me access to my funded account through Sierra instead of Tradeview which is what I grasped from reading that page. I hope the Denali data will be readily visible once that happens Regards |
[2021-12-28 17:22:10] |
John - SC Support - Posts: 38368 |
First, you need to go through all of the Setup Instructions for the Denali Exchange Data Feed here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* Note that you will need to pay the full amount for the exchange fee for the remainder of the month. So you might want to wait until January 1, 2022 before you activate the exchanges you want, so you do not pay the full amount just for the next 3 days (assuming you have your trading account setup right away as well). Once you have all the steps completed for the Denali Exchange Data Feed, then you will need to connect your Sierra Chart to your trading account. If you are getting setup through AMP, then most likely you will be setup with CQG for your Order Routing. If this is the case, then you will need to follow the instructions at the following link to connect your Sierra Chart to CQG: CQG Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
