Date/Time: Tue, 04 Mar 2025 18:57:38 +0000
[User Discussion] - GOOD TIME PLEASE ADVISE
View Count: 546
[2021-12-28 15:11:07] |
User413489 - Posts: 21 |
GOOD TIME PLEASE ADVISE, I HAVE THE FOLLOWING SERVICES : Sierra Chart Usage Time at Service Package 3 - Standard. Exchange Data Feed: 750 Real-Time Symbols (1st Connection). Activated Exchange: U.S. Equities (NYSE, NASDAQ, AMEX) IF I DISABLE THE SERVICE -750 Real-Time Symbols (1st Connection). BECAUSE I DON'T SEE IT FOR MY PURPOSES YET WILL I HAVE ACCESS TO THE DATA (NYSE, NASDAQ, AMEX) WITH A DELAY OR AT THE END OF THE DAY ? Translated with www.DeepL.com/Translator (free version) |
[2021-12-28 17:18:08] |
John - SC Support - Posts: 38369 |
If you deactivate the Sierra Chart Exchange Data Feed, then you will get the U.S. Equities data updating at the interval defined by the setting Global Settings >> Data/Trade Service Settings >> Intraday Download Interval for Non-Real-Time Symbols. The lowest this can be set is every 20 minutes and the data will be 10-15 minutes behind the real-time. For more information, refer to the information about our historical data service at the following link: Sierra Chart Historical Data Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-29 23:32:41] |
PLEASE TELL ME WHAT TO GET DATA AT THE END OF THE DAY ON THE U.S. STOCK STANDARD PACKAGE IS ENOUGH ?
[2021-12-31 14:40:51] |
Any Sierra Chart package will allow you to get the End of Day data for the U.S. Stocks.
[2021-12-31 15:47:23] |
For this you want to use the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
