Date/Time: Tue, 04 Mar 2025 18:04:07 +0000
Customize Control Bars
View Count: 736
[2021-12-27 18:09:47] |
User672422 - Posts: 8 |
How can I copy Customize Control Bars and other customization I make in the main Sierra Charts to New Instances? I copied the Sierra3.cfg file from the C:\SierraChart\SierraChartsTransActMA folder to ..\SierraChartInstance_2 folder but this did not work. |
[2021-12-27 20:55:00] |
Refer to this help topic: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation The Control Bar configuration is contained within the Sierra4.config file. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-12-27 20:55:11
