Date/Time: Tue, 04 Mar 2025 18:06:05 +0000
tracez des lignes sur autre graphique
View Count: 938
[2021-12-27 15:21:53] |
Utilisateur188232 - Posts: 22 |
Bonjour, comment puis je faire pour que mes lignes tracées sur un graphique se trace aussi sur un autre graphique du même actif ? Merci de votre réponse. |
[2021-12-27 19:24:42] |
GravisHTG - Posts: 306 |
press f5 on your charts, then select advance settings 2 , then bottom right you will see COPY CHARTS DRAWINGS FROM CHARTS # , get the right # and your set.
[2021-12-27 21:00:31] |
For what you want to do, refer to the documentation here for this: Copying Chart Drawings from Other Charts Automatically Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
