Date/Time: Fri, 07 Feb 2025 14:51:40 +0000
Backtest
View Count: 571
[2021-12-27 15:14:09] |
Aurèlien Pèromet - Posts: 2 |
Hello, I would like to backtest a strategy but my color bar indicators etc stop at 2021.21.14. I think because of the rollover. (My chart is well downloaded over several months and the option (continuous future contrct, volume based rollover back adjusted and well in place.) thank you |
[2021-12-28 15:51:20] |
John - SC Support - Posts: 37808 |
It sounds like you are saying that your "Color Bar Based on Alert Condition" study is not coloring anything past December 14, 2021. If this is correct, then you would have to look at the alert conditions for the study and see why you would not get any true signals after that date. It would definitely not be related to the rollover. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-24 14:08:12] |
The study also has an Input to control the number of bars it is calculated over. Check that Input setting.
