Date/Time: Tue, 04 Mar 2025 18:17:27 +0000
Remote build produces fat code
View Count: 530
[2021-12-26 14:58:44]
Ed C. - Posts: 117
When I build a DLL with SC "Build with Visual C++ Release" from the "Build Advanced Custom Studies DLL", the DLL is around 150K in size. When I use the remote build functionality, the received DLL is over 900K!
Is there any way to reduce the side of the received DLL from the remote build functionality?
[2021-12-26 15:00:30]
No, it must have something to do with the included libraries.
[2021-12-26 23:56:31]
Ed C. - Posts: 117
Since the DLL is built on your server, this must be a question that only you can answer. Can you provide more insight?
[2021-12-27 01:51:16]
No we cannot answer this. We have long known about this. It must be related to the GCC compiler. It is not anything we can improve upon.
It should not be a concern. The extra size should not matter.
Date Time Of Last Edit: 2021-12-27 01:51:28
