Date/Time: Tue, 04 Mar 2025 17:55:58 +0000
Pivot Points Study Is Missing Mid Point Levels
View Count: 643
[2021-12-26 13:37:25]
User410071 - Posts: 2
Hello, I wanted to bring to your attention that the Pivot Points study is missing very important levels called Mid Points. I for instance only use the Mid Points for trading and hide all the other levels (The S and R).
Can you please add those levels to the study in the next update? Here to make it easy for you:
Mid-pivot points
Pivot points that are between the pivot points are call mid-pivots. They are labelled differently. The mid-pivot between the S1 and S2 is labelled as M1, the mid-pivot between the S1 and the main pivot is M2 and so on.
Calculating mid-pivots
Mid-pivots are simply halfway between the main pivot points. The calculations for mid-pivots are as follows:
M1= (S2+S1)/2
M2= (S1+PP)/2
M3 = (R1+PP)/2
M4 = (R2+R1)/2
Another suggestion would be to also add a single study "Pivot Points Mid Levels Only", would show only the mid levels.
Best regards
Date Time Of Last Edit: 2021-12-26 13:39:27
[2021-12-26 14:18:31]
User907968 - Posts: 833
Formula type 13 already has those levels - Pivot Points: Formula Type 13
You can rename using the short name, if you prefer the M1-M4 naming.
Date Time Of Last Edit: 2021-12-26 14:19:58
[2021-12-26 14:52:10]
Hi thanks! Ok I see now, the .5 and the 1.5 levels are the M1, M2, M3 and M4
BUT it´s impossible to rename the subgraphs. How do we do it?
EDIT:
My apologies, I See now the field "short name". It was in front of me the whole time lol. All set now.
By the way, all formulas have the 0.5 1.5 levels for the M1 to M4
Date Time Of Last Edit: 2021-12-26 15:51:33
