Date/Time: Tue, 04 Mar 2025 18:16:07 +0000
Number bars
View Count: 650
[2021-12-26 06:34:27]
User575399 - Posts: 326
Is their a way to highlight large orders in the number bar study ? Example pic
Private File
[2021-12-26 08:57:51]
If you are looking for large orders you need to use this study:
Large Volume Trade Indicator
[2021-12-26 17:02:57]
Yeah that didnt work . I just want to color the orders in the bars according to volume . For example : orders over 100 bid could be dark blue and ask over 100 could be yellow. Any ideas?
imageScreenshot (288).png / V - Attached On 2021-12-26 17:02:51 UTC - Size: 170.2 KB - 153 views
[2021-12-26 20:47:43]
Ok I figured it out.
One more question : can I make the font of just the larger orders bigger than the other number texts in the number bar study? Thanks !
[2021-12-26 22:34:29]
You can Bold text that exceeds a certain value. Refer to this Study Input:
Numbers Bars: Bid / Ask Bold Threshold
Date Time Of Last Edit: 2021-12-26 22:34:48
[2021-12-29 07:11:58]
I saw that setting, I changed it and nothing is bold . Any ideas ?
[2021-12-29 13:18:30]
Maybe you are already using a bold font in the chart? It may not make much noticeable difference depending upon the particular font being used.
Date Time Of Last Edit: 2021-12-29 13:18:36
