Date/Time: Tue, 04 Mar 2025 18:23:02 +0000
Upcoming changes for CQG (order routing only) users?
View Count: 670
[2021-12-25 01:18:49]
dubbs - Posts: 36
Hi, I have been using Sierra Charts Denali data feed package #10 with my AMP futures trading account with CQG (order routing only) to trade with Sierra Charts. On the support board thread "New Teton Order Routing Service for CME, CBOT, NYMEX, COMEX, FairX, upcoming EUREX" in the first post it says "during 2022 we want to move our CQG users onto this new service, unless you require exchanges that are not covered by this service."
My question is, will I be able to continue using CQG (order routing only) with my AMP futures trading account and the Sierra Chart Denali data feed package 10? Or will I be required to change sometime in the near future?
I want to use the new Teton Order Routing Service with AMP, but as you know, AMP is being very hesitant about allowing this to happen. So I would like to continue using the setup that I have been until AMP offers the option to use this new Teton Order Routing Service. thanks
[2021-12-25 05:40:30]
For a period of time but eventually we will increase the required Service Package level to our highest level to use CQG.
We do not have a date on that but not before May 2022.
Therefore consider moving your account from AMP:
Date Time Of Last Edit: 2021-12-25 05:47:04
[2021-12-25 14:29:25]
dubbs - Posts: 36
"For a period of time but eventually we will increase the required Service Package level to our highest level to use CQG."
so are you saying that when this change occurs, I would still be able to continue to use Sierra Chart Denali data feed with AMP and CQG (order routing only) if I upgrade to that highest level service package at that time?
And also, are you saying that I will be able to continue using my current setup to trade futures with AMP and CQG until at least May or whenever that change occurs?
I would like to stay with AMP because they offer very low day trading margin requirements and very low minimum account requirements so this setup has worked great for me. Does anyone know of any clearing firms or introducing brokers who are currently allowing traders to use the Sierra Chart Teton Order Routing service and have very low day trading margin requirements and low minimum account deposits to get started similar to AMP?
[2021-12-25 16:20:07]
Yes but we would expect by then AMP to be supporting the Teton order routing.
It is hugely advantageous for them to be supporting it.
[2021-12-26 01:33:05]
dubbs - Posts: 36
OK, thank you very much. I agree, the sooner the better as far as AMP supporting the Teton order routing. I have emailed them in an effort to encourage them to support this great order routing service.
