Date/Time: Tue, 04 Mar 2025 18:15:22 +0000
Separating Date and Time in Spreadsheet
View Count: 763
[2021-12-24 20:26:05]
User148824 - Posts: 10
The 'Date Time' is the first column in DefaultSpreadsheet.
It shows as the Date and Time in the same column:
2021-12-23 15:58:00
Can the Date and Time be separated into two separate columns in the Sierra chart spreadsheet?
[2021-12-25 05:10:49]
Sawtooth - Posts: 4179
To extract the Date only, use the INT function in a Formula Column's row 3:
=INT(A3)
To extract the Time only, use the FRACTIME function in a Formula Column's row 3:
=FRACTIME(A3)
https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#INT_Function
https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#FRACTIME_Function
[2021-12-25 05:19:51]
There is also this function:
https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#INTDATE_Function
