Date/Time: Tue, 04 Mar 2025 17:59:00 +0000
dwgs form other chart are showing up on a chart when COPY CHART DWGS FROM CHART # is blank
View Count: 579
[2021-12-23 21:51:01]
User475862 - Posts: 31
Hi
Drawings form other chart are showing up on a chart when COPY CHART DWGS FROM CHART # is blank
example in the attached pictures I drew the SOLID lines in chart #3. yet ALL the lines i drw in chart 1 and 2 are showing up in chat 3 yet the Copy Chart Drawings from Chart 3's is BLANK. if i deselect he show chart dwgs for different symbols ALL the lines disappear.
why the lines i have drawn in chart 1&2 are showing up in chart 3.
By the way in Chart 1 I have selected to copy lines from Chart 3 but the lines form chart 2 also show up!!!
imagechart deawing from other chart when none are selcted Screens.jpg / V - Attached On 2021-12-23 21:50:04 UTC - Size: 538.58 KB - 147 views
imagechart deawing from other chart when none are selcted .jpg / V - Attached On 2021-12-23 21:50:14 UTC - Size: 507.17 KB - 130 views
imagechart deawing from other chart when none are selcted 2.jpg / V - Attached On 2021-12-23 21:50:26 UTC - Size: 475.08 KB - 137 views
[2021-12-23 22:15:11]
John - SC Support - Posts: 38368
Since the Copy Drawings from Chart #'s is blank in Chart 3, then the drawings are not actually coming from those other charts. It sounds like those drawings were there from a previous contract in that same chart, which is why they show up when you select Show Chart Drawings for Different Symbols.
In the end, you will need to open Tools >> Manage Chart Drawings Window and determine the source of the drawings. If the drawing is coming from another chart, then it will NOT be displayed in this window. Refer to the following regarding this window:
Chart Drawing Tools: Manage Chart Drawings
[2021-12-23 22:45:52]
Ah, i had copied the dwgs in chart 2 instead of plotting a new line!!!! so teh copied line in chart 2 is actually a line form chart 3.
Deleted all lines and replotting each chart separately with a new line rather than copy.
thanks for your help
