Date/Time: Tue, 04 Mar 2025 18:04:08 +0000
positions closing order
View Count: 691
[2021-12-23 16:15:35]
User156295 - Posts: 104
Could you guide me how to understand the order of closed positions. Why it was 1-st position to be closed when it was 2-nd position that got hit it's SL.
All is shown on attached chart.
image2021-12-23--.png / V - Attached On 2021-12-23 16:13:47 UTC - Size: 125.55 KB - 162 views
[2021-12-29 14:54:45]
Some guidance pls
[2021-12-29 15:07:21]
User907968 - Posts: 833
Maybe this ---> Chart Settings: Use Last In First Out Fill Matching (Chart >> Chart Settings >> Trading menu)
Date Time Of Last Edit: 2021-12-29 15:07:58
[2021-12-29 15:21:51]
and this is not enabled in chart settings, by default
any suggestions pls?
[2021-12-29 15:23:15]
So enable it then, if you want LIFO instead of FIFO matching.
Date Time Of Last Edit: 2021-12-29 15:23:40
[2021-12-29 15:37:26]
thanks, I digged more and I think found the origin thread of this matter here
Change trade order to LAST IN FIRST OUT | Post: 169367
and yes, definetely LIFO needs to be enabled
thank you !
question - is there any possibility to enable LIFO by default for each chart smwr in general settings not only separately on each chart, I suspect no but who knows ...
[2021-12-29 23:46:49]
Refer to:
Using Chart Templates
