Date/Time: Tue, 04 Mar 2025 18:21:27 +0000
question about "volume at price threshold alert V2"
View Count: 923
[2021-12-23 04:22:46] |
User290950 - Posts: 13 |
Hello I have a question about "volume at price threshold alert V2" I use it to find imbalance In my setting Draw Extension Line is "All Alert" and "Highlight adjustment alerts minimum group size is 2 Everything is Ok but I don’t want to see extended lines on single imbalance, I what to draw lines if minimum group size is 2 or more, Is there any way? Please see attached images Thank you |
[2021-12-23 16:17:37] |
John - SC Support - Posts: 38369 |
Just select one of the options for the Input Draw Extension Lines that states ...In Adjacent Alerts. Refer to the information for this Input in the documentation here: Volume at Price Threshold Alert V2 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
