Date/Time: Tue, 04 Mar 2025 16:37:29 +0000
Connecting Data In Trial of Sierra
View Count: 852
[2021-12-22 19:03:49] |
FatTailHunter - Posts: 8 |
Hello, I am an independent speculator and currently using Interactive Brokers as my broker/fcm for my futures trading. I recently came across Sierra when I became frustrated with the DOM, data quality, and analysis capabilities of ibkr's software for short term trading. I reached out to Dorman Trading and spoke with them about opening an account and routing with Sierra directly through the new service you are offering. What I would like is the ability to connect my interactive data feed during my 14 day trial of Sierra in order to do some paper trading and get a better feel for the Sierra software without needing to make an initial deposit with Daniels or purchasing a Denali data package without having made up my mind. I hope this wasn't answered elsewhere, if so my apologies. Best Regards - aegeanfutures
[2021-12-22 20:22:57] |
We really recommend you just use our Simulated Futures Trading service: Simulated Futures Trading Service Instructions are on the page linked above. Very easy to get started with that service. Use Trading Evaluator-Delayed. We would rather you do not connect the Interactive Brokers and then have a poor impression caused by the issues you will encounter. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-12-22 20:23:24
[2021-12-22 20:52:07] |
I have another issue but related to your suggestion. I have Sierra pulled up but had not noticed my account information was incomplete on the form so was not able to run the trading evaluator-delayed, not access any other delayed data on Sierra. I have completed the form and was hoping you could help me gain access? Thank you for your prompt reply and help with this, it is much appreciated.
[2021-12-23 15:12:27] |
Your trial required activation and this is now done.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-12-23 15:12:33
