Date/Time: Sun, 20 Sep 2026 07:46:43 +0000
Global Profit and Loss Management disabled from SC start
View Count: 1643
| [2021-12-22 18:49:15] |
| nosast - Posts: 324 |
Today I noticed that after every restart of SC the Global Profit and Loss Management is disabled! That is a quiet substantial feature I rely on and for years GPNL was active right from the start. I updated to 2337 but still the same issue causing all GPNL functions to be disabled. - Flatten when Profit rules met - Trail daily profit - Net loss management - Flatten after set time Is there any new setting I'm not aware of or how can this be fixed? |
| [2021-12-23 15:21:54] |
| GreyLock58 - Posts: 173 |
Same here...ver 2335
| [2021-12-23 16:53:57] |
| John - SC Support - Posts: 47939 |
There is a setting on the Global Profit and Loss Management in the bottom right-hand corner that states Disable Global Profit/Loss Management On Startup. You would want this to be disabled in order to have the functionality running when you start Sierra Chart. Refer to the following: Global Profit/Loss Management: Disable Global Profit/Loss Management on Startup For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-12-23 16:55:37] |
It is disabled. And same problem
| [2021-12-23 16:57:12] |
Same here. Disable GPNL is "disabled" so GPNL should be enabled on startup.
| [2021-12-27 04:04:57] |
This is resolved in the latest release.
