Date/Time: Tue, 04 Mar 2025 15:59:54 +0000
Trading DOM
View Count: 690
[2021-12-22 16:22:10]
User841161 - Posts: 248
Trying to change the Trading DOM settings-to start was trying to change column backgrounds.. Doing thru Chart and Graphic Settings and have use Global Settings unchecked. Background settings do not seem to be taking.
imagedom12-22.png / V - Attached On 2021-12-22 16:21:39 UTC - Size: 291.51 KB - 153 views
[2021-12-22 17:25:29]
Bet_More_Tim - Posts: 21
Did you try changing the "Trade DOM" settings and not the "Chart DOM" settings?
[2021-12-22 17:29:54]
Notice to the right of that color setting where it says "Enable". Enable that checkbox.
And yes you would need to use the Trade DOM equivalent setting as well.
And make sure you are opening the Graphics Settings window, for that particular trading DOM.
Date Time Of Last Edit: 2021-12-22 17:30:40
