Date/Time: Tue, 04 Mar 2025 18:23:45 +0000
Fully Reset a Window
View Count: 921
[2021-12-22 14:53:08]
TraderTom - Posts: 25
My add-in Zones drop out when re-activating them to rewrite them or other reason. The window has no zones then. The only way I can get them back that I know is exit the program. When I restart Sierra Chart the Zones all write okay.
Is there a way to rewrite one window to get the Zones after they have disappeared? Can one window, as a trading window, be reloaded as if it were started with the starting program?
Tom Ellis
[2021-12-22 15:09:09]
We really do not know what you are referring to. Are you referring to a study added to a chart?:
Chart Studies
[2021-12-22 16:32:39]
Can I reset a Window that has a study that plays a text file to draw zones on a chart? The only way I know to replay the text file to draw the zones is re-start Sierra Chart. I would like to redraw the zones without having to re-start the software.
Tom Ellis
[2021-12-22 16:42:00]
Yes what you can do is go to that chart and select Chart >> Reload and Recalculate:
Chart Menu: Reload and Recalculate (Chart menu)
[2021-12-22 18:06:59]
Thank you. But that did not reload the window as it is set up when the program starts. Here are two lines of the text file that writes the zones:
4740.25,4743.25,R,Normal
4731.75,4733.75,R,Normal
What can I do to get the zones re-written without re-starting the program?
Tom Ellis
[2021-12-23 15:56:31]
John - SC Support - Posts: 38369
It sounds like you are using a custom study, therefore you would need to figure out why these items are being removed and not redrawn. We simply do not know.
