Date/Time: Tue, 04 Mar 2025 16:24:03 +0000
Package 11 data
View Count: 640
[2021-12-22 12:29:18] |
Jamesq3 - Posts: 7 |
I have just paid for the package 11. Does this mean I get the data for free for 6 months, and if so how do I activate it?
[2021-12-22 14:10:20] |
It depends what "Data" you are referring to. What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. You do have to pay exchange fees if you want real-time futures data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-12-22 14:10:37
[2021-12-22 14:25:21] |
GU, Gold, S&P and Crude
[2021-12-22 14:53:00] |
Pound futures, gold, S&P + Crude
[2021-12-22 14:54:47] |
So it says Denali Data feed included but I still have to pay for the full CME group feed?
[2021-12-22 15:28:36] |
Yes you do. You need to activate the exchanges you require here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
