Date/Time: Tue, 04 Mar 2025 16:00:32 +0000
Teton Routing & SC Exchange Data Feeds
View Count: 533
[2021-12-22 05:34:45]
User570608 - Posts: 4
I have just switched to the new Teton routing services for trading and that’s working fine with the Denali Feed. I also have SC Exchange Data Feed setup for real time HKFE data but I cannot see those now. Do I have to run another Sierra instance and choose SC Data - All Services to access that data again? If so, can I run it from a different computer? And would that affect my Denali feed with the Teton routing services? I only need Denali on 1 system with the Teton routing services. Thanks
[2021-12-22 14:19:24]
This is the preferred method:
We could include the Hong Kong Futures Exchange symbols for the Sierra Chart Teton Order Routing service. It is quite easy. However, we would like to avoid the confusion with the additional symbols.
Yes.
No not at all.
Here are instructions:
Using Multiple Data and Trading Services at the Same Time
Date Time Of Last Edit: 2021-12-22 18:18:42
