Date/Time: Sat, 04 Jul 2026 03:57:41 +0000
Connect SC to External Program for AI analysis
View Count: 1380
| [2021-12-22 01:40:51] |
| User769783 - Posts: 208 |
Hello, hopefully the title gives it away. I need to know how I can achieve this. I want to run data from Sierra into an AI model, in real time, and have it make predictions and place the orders in Sierra. Are there external programs from 3rd party developers for this? Can I use the FIX or DTC? This is beyond my skill level and I could use some help and advice. Thanks in advance.
| [2021-12-22 02:31:55] |
What we can help you with is accessing the data from Sierra Chart. You will want to use the DTC Protocol Server for this: Data and Trading Communications (DTC) Protocol Server As far as what third-party program can do what you need, we do not know . Most likely you need to just develop what you need. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-12-22 02:32:16
