Date/Time: Tue, 04 Mar 2025 16:12:48 +0000
2 instances of SC, 2nd instance trade window
View Count: 496
[2021-12-21 20:17:18]
Tonkadad - Posts: 235
When running 2 instances of SC anyway to get the 2nd instance's trade window to be "Always on Top" so it can be below
the 1st instance trade window.
imageAlways on top.png / V - Attached On 2021-12-21 20:17:05 UTC - Size: 182.62 KB - 158 views
[2021-12-21 21:52:15]
John - SC Support - Posts: 38351
You can not do this directly, but the following "workaround" gives you what you want.
Open a Trading DOM for the chart you want the Trading Window for, and then change the size of the window until just the Trading DOM is displayed.
You can then set the option Window >> Always On Top for that Trading DOM to get what you want.
[2021-12-21 22:18:55]
Thank you, I found these links explaining in depth what you told me to do.
Window, CB and CW Menus: Always on Top (Window)
Detaching and Attaching Chart Windows
Detaching and Attaching Chart Windows: Setting Detached Chart to Be Always on Top
