Date/Time: Tue, 04 Mar 2025 16:34:24 +0000
Trading Gold options with Sierrachart
View Count: 590
[2021-12-21 19:15:39] |
User819475 - Posts: 1 |
Hello, I would like to know if it is possible to trade GC Gold options(calls and puts) on sierrachart, when I bought the comex data feed there was still no Gold in the options symbol section. If you do support options trading for Gold please advise further. Also will it display delta, theta, implied volatility etc and allow for strategies eg butterfly, condor spreads etc. |
[2021-12-22 14:51:00] |
Gold options are supported. Refer to the attached screenshot for options market data support from the Denali data feed. Instructions: Real-Time Exchange Data Feeds Available From Sierra Chart: Futures Options Also will it display delta, theta, implied volatility etc and allow for strategies eg butterfly, condor spreads etc. No.Options trading is only supported through CQG, Interactive Brokers and Rithmic. In all cases we recommend using the Denali Exchange Data Feed: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-12-22 15:01:24
