Date/Time: Tue, 04 Mar 2025 15:58:44 +0000
Stationary Text not Stationary
View Count: 602
[2021-12-21 19:09:48]
User837393 - Posts: 143
I'm in the process of puting reminders and notes on my charts using the Stationary Text Tool. Unfortunately the text scrolls with the chart, making it behave like it is NOT stationary.
Anything i'm missing ?
[2021-12-21 21:32:17]
John - SC Support - Posts: 38349
If the text is moving with the chart, then the only logical conclusion is that you did not select the Stationary Text tool, but rather the Type Text tool. Take a look at your selection in the Tool menu and see.
Also, refer to the following for the difference between these two tools:
Chart Drawing Tools: Type Text | Stationary Text
