Date/Time: Tue, 04 Mar 2025 21:24:56 +0000
[User Discussion] - How to get white characters on black labels?
View Count: 552
[2021-12-21 18:05:38]
User429065 - Posts: 128
The numbers on the black labels are too dark to see. How can they be changed to white?
imageDark Labels.JPG / V - Attached On 2021-12-21 18:04:18 UTC - Size: 23.67 KB - 138 views
[2021-12-21 18:18:51]
John - SC Support - Posts: 38369
It depends on where those items are being displayed from. If you can tell us how you are getting those to display, then we can point you in the right direction.
[2022-01-01 18:47:45]
See attached, thx!
imageDark Labels.JPG / V - Attached On 2022-01-01 18:47:15 UTC - Size: 23.67 KB - 133 views
imageLabels too dark on black.JPG / V - Attached On 2022-01-01 18:47:24 UTC - Size: 108.57 KB - 123 views
[2022-01-03 20:51:07]
The colors of the Labels is going to follow the colors for the particular subgraph. In this case, the color options are black and white. One of your options is to uncheck "Reverse Colors" and see if that will give you what you want.
Otherwise the only other option would be to use either another copy of the same study (with the exact same Inputs) or the Study Subgraph Reference Study, but set the Subgraph Draw Type to Subgraph Name and Value Labels Only. Then you can set the colors as you desire and get the labels as you want and not impact the original lines that you have.
Refer to the following for the "Subgraph Name and Value Labels Only" Draw Type:
Chart Studies: Subgraph Name and Value Labels Only (ACSIL: DRAWSTYLE_SUBGRAPH_NAME_AND_VALUE_LABELS_ONLY)
