Date/Time: Tue, 04 Mar 2025 21:25:37 +0000
rectangle
View Count: 550
[2021-12-21 14:16:51]
User138457 - Posts: 38
Is it possible to have two different colors in rectangles?
I often want to draw, say
a blue one
two red ones,
then a blue one again.
Changing this over the "tool config" is quite cumbersome
Any alternatives?
[2021-12-21 14:23:17]
Yes. You can create Control Bar buttons that consist of both a particular drawing tool and a configuration, up to 24 configurations. Documentation:
Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step (Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step)
Each configuration would use a different color in your case.
Date Time Of Last Edit: 2021-12-21 14:23:58
[2022-01-05 22:43:29]
perfect, thanks. Could ypu also tell me in what config file
these toolbar settings are stored?
[2022-01-06 14:40:40]
John - SC Support - Posts: 38369
Colors, control bars, and global settings are in the file named 'Sierra4.config' (no quotes). Refer to the information in the following section for what the different files have in them:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
