Date/Time: Tue, 04 Mar 2025 15:08:51 +0000
DOM as a set of Bars, not Numbers
View Count: 528
[2021-12-20 20:07:58] |
User964846 - Posts: 38 |
Could you help me understand how to turn those DOM numbers into Bars? Greatly appreciated. thank you! |
[2021-12-20 21:47:22] |
John - SC Support - Posts: 38343 |
Refer to the following setting: Global Trade Settings Windows: Show Volume Bars (Trade >> Customize Chart/Trade DOM Columns) The numbers can not be removed. You can try changing their color to the same as the background, but when the bar extends into where they are drawn, you will still be able to see them. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
