Date/Time: Tue, 04 Mar 2025 18:00:04 +0000
Account with AMP futures routing
View Count: 835
[2021-12-20 19:22:33] |
aj_7sun - Posts: 5 |
Hi - I am new to sierra charts , and also opened futures account with AMP futures . ( CQG - Order routing only ). I would like to use denali data feed and link the CQG account details with sierra charts. Could you please advise how to get this done ? Regards, Arun. |
[2021-12-20 19:31:03] |
John - SC Support - Posts: 38368 |
First, connect your Sierra Chart to CQG by following these instructions: CQG Trading Platform Service: Setup Instructions Then setup the Denali Exchange Data Feed for CME Group data by following the instructions at this link (if you need data for EUREX or CFE, then those instructions are on the same page, just scroll to the top and select the appropriate link): Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* After the setup for the Denali Exchange Data Feed is complete, then open your Chartbooks and select Edit >> Translate Symbols to Current Service. This ensures that your symbols are set properly for CQG. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-24 11:48:28] |
Hi - Thanks , I am able to connect successfully . However , I would like to have US stocks real time data as well . Is there any add on package I need to add along with my Denali package or how do I do it ? Thanks , Arun |
[2021-12-24 21:43:23] |
This will be available in January with our new NASDAQ data feed coming out then.
