Date/Time: Tue, 04 Mar 2025 18:23:45 +0000
Time seting
View Count: 629
[2021-12-20 15:28:12]
User586893 - Posts: 4
Hi there, My setting was correct and now ever since I rolled over to the next contract I realised some of my charts are showing the different times but just ahead with like 27 seconds. So for this reason my order fills are not in the correct place. Can I have some guide on how to solve it?
[2021-12-20 16:52:52]
John - SC Support - Posts: 38369
We are not sure we understand where you are seeing the difference of 27 seconds.
But, in general if you are comparing the chart to your computer clock, then your computer clock would be off by 27 seconds. If you want to sync your computer clock to our servers in order to have the same time in your charts and computer, then refer to the following:
Global Settings Menu: Set System Date-Time from Server (Global Settings menu)
[2021-12-23 16:27:23]
Refer to:
Chart Trading and the Chart DOM: Misaligned Order Fill Markers on Charts
