Date/Time: Tue, 04 Mar 2025 17:58:36 +0000
Date Range In File
View Count: 1025
[2021-12-20 11:59:34]
User909795 - Posts: 4
I'm trying to examine tick by tick data.
I followed the guide and verified I can see tick-by-tick data.
However, I can't seem to change the beginning date.
I could see that data starts at the "Date Range In File", showed under "Chart>>Chart Settings".
I see that under "Edit>>Edit/Download Data - intraday chart", by scrolling to "Start of File".
Please advise.
King regards,
Roy
Date Time Of Last Edit: 2021-12-20 12:17:39
[2021-12-23 16:20:49]
Refer to:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data
[2021-12-23 16:44:19]
I did (already before posting this message).
Still, the oldset date I can see is 2019-11-25 (didn't change at all).
[2021-12-23 16:54:49]
One more thing - can I export tick-by-tick file for continuous futures?
I would like to use your "volume based" rule, so exporting each expiration would not suffice for me.
Thanks,
Roy
[2021-12-23 17:17:01]
John - SC Support - Posts: 38368
What is the symbol for which you are not able to get the older data?
To export the data that is displayed in the chart use this option:
Edit Menu: Edit >> Export Bar Data to Text File
[2021-12-24 09:14:01]
CLG2 (continuous - volume based)
[2021-12-24 10:51:10]
That is not a correct symbol.
Provide an image of the chart or Trade DOM, by following these instructions:
