Date/Time: Tue, 04 Mar 2025 18:07:03 +0000
TETON Futures Spread Order Through DTC Protocol
View Count: 725
[2021-12-20 07:52:14] |
User470294 - Posts: 8 |
We are configured with Teton and want to place Futures Spread Orders through the DTC Protocol. Looking at the documentation we don't see a clear way to do this. On the Trading DOM under the A tab, we see the option to Enter Spread Orders manually. How do we place this order through the DTC Protocol? Thanks |
[2021-12-20 13:31:49] |
You just simply use the spread symbol. But we have to do some additional set up for spreads for the Teton order routing service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-12-20 13:32:09
[2021-12-23 16:20:04] |
We are done with support for trading spreads. We do need to do a software update. What products do you want to trade spreads for? So we can add the necessary symbol settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-12-23 16:20:16
[2021-12-23 21:22:02] |
ES, NQ and CL for now. Thank you.
[2021-12-24 22:39:43] |
Ok these are set up. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings But we have to do a new release which we will do Monday evening, and we have to provide some information and instructions to Phillip Capital regarding the below: Trade Account and Risk Management: Trading Spreads and Position Reporting for Spreads Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-12-24 22:59:13
