Date/Time: Wed, 05 Mar 2025 01:41:26 +0000
TETON Futures Spreads
View Count: 723
[2021-12-20 07:48:19] |
User470294 - Posts: 8 |
We are configured with Teton. We are getting "Symbol settings not found for current service" when we open a Trading DOM for Futures Spread Products. We opened the Trading DOM using using the Find Symbol -> Get Spread process. The symbol that was returned from the Find Symbol -> Get Spread was "NQH22-NQM22.FUT_SPREAD.CME" We were told Teton would give us the ability to trade Futures Spreads. Any idea what's wrong? |
[2021-12-20 13:23:24] |
Spreads are supported but we have to do some additional set up for them and testing related to margin data. We will have this done before the end of the week. If you need to urgently trade the spreads, have the clearing firm move you to the TT based order routing for now: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-12-20 13:26:18
[2021-12-20 15:44:43] |
There is not much work we need to do with spreads and we probably can have this done either today or tomorrow, unless a software update is needed. Can you tell us what clearing firm you are using. We need to have them do configuration on their side as well to support the particular spreads you want to trade.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-12-20 15:45:01
[2021-12-20 17:12:44] |
We're with Edge
[2021-12-20 17:16:09] |
Thank you. Is the clearing firm Phillip Capital or Dorman?
[2021-12-20 17:21:07] |
Phillips
[2022-01-10 04:28:17] |
Sierra_Chart Engineering - Posts: 18656 |
Letting you know this was set up, and Phillip Capital was informed.
[2022-01-11 20:33:49] |
SpearChucker - Posts: 104 |
And status with Dorman?
[2022-01-11 22:31:21] |
So you want to trade spreads through Dorman as well?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-11 22:31:26
[2022-01-11 22:49:11] |
As well? I'm using SC/TT Futures Order Routing and clear thru Dorman. I would like to change to the Teton Order Routing, but saw this thread about spreads. Just my way of asking if Teton is good to go for spreads (with Dorman). Maybe I'll save the question for Anthony during the Q&A in Edge Clear's webinar tomorrow. Date Time Of Last Edit: 2022-01-11 22:51:12
