Date/Time: Tue, 04 Mar 2025 14:51:54 +0000
Absolute value?
View Count: 660
[2021-12-19 20:02:57] |
User203781 - Posts: 55 |
Is there really no function for absolute value? I need it for an alert study and can't find one for any sort of study. If it exists, please give me a clue. Thanks. |
[2021-12-19 20:03:35] |
Bet_More_Tim - Posts: 21 |
https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#ABS_Function
[2021-12-19 21:40:53] |
The function linked above can be used with Simple Alert Formulas and Spreadsheets. There is also this study: Study Subgraph Absolute Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
