Date/Time: Tue, 04 Mar 2025 15:05:06 +0000
New free trial account requires activation
View Count: 732
[2021-12-19 18:36:46] |
User930175 - Posts: 2 |
Hello, I've recently registered for a free trial account and it appears that my account has not yet been activated as I got the below error message. Could someone pls help activate my account? Thanks THIS ACCOUNT REQUIRES ACTIVATION! The features available have been restricted. You do not have access to the features normally available with the free trial. |
[2021-12-19 21:39:33] |
Your account has been activated and the usage time extended if necessary. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
