Date/Time: Tue, 04 Mar 2025 14:56:29 +0000
Feature request: Save fonts in "Saved Graphic Settings"
View Count: 580
[2021-12-18 05:36:31] |
User601931 - Posts: 11 |
I am switching between a laptop & a 4k monitor and having a problem preserving the font settings between configurations. I expected the global graphics configuration settings to include all options on the form, but it seems to only save the "Color & Width" tab. It appears the font tab is not saved in the users configurable graphics settings. To reproduce this: 1. Open Graphic Settings - Global. On the color & width tab, save the current configuration as #1 2. Go to the font tab. Change chart text to a big font, like 20. 3. Go back to Color & Widths. Change a visible property, like candle color to purple or something obvious. 4. Save the configuration as #2. 4. Goto Global settings -> Graphic Setting Configurations -> Toggle between #1 & 2. The chart colors change, but the fonts do not follow. Can you add a way to save the fonts in the configuration as well? Even if it is just a check box option to include fonts in the config save. Or if there is a better way to move between monitor resolutions, please let me know. Thanks. |
